Ir para o conteúdo principal
Lançado em julho de 2008 pela Acer Inc., este netbook pode ser identificado na família ZG5 Acer Aspire One pelo número de modelo A150-1672.
My computer is frozen and unresponsive.
Randomly my computer froze and the mouse won't move on screen. I can't pull up the task manager or get anything to happen. When I press the power button, it will go to a black screen, but when I hit it again, it comes back to the same frozen screen.
Esta é uma boa pergunta?
Pontuação 2
2 comentários
student question
por
My CP is stuck frozen how do I get it unfrozen
por
Adicionar um comentário
4 respostas
Solução escolhida
The computer may be taking in too much input or there could be a malfunctioning program or application.
Since you can't restart the computer on-screen, the best way to fix this is to do a hard reset by either holding down the power button until the computer totally shuts off, or by removing the battery.
After this, it may also be good to do a system restore to a time before your computer froze to make sure that there weren't any changes to your computer that caused the freeze.
Esta resposta foi útil?
Pontuação 1
My pc doesnt work when i turn it on my mouse doesnt move on screen restart it and the pc is still frozen please whoever fixes this I need help.
Thank You
Pontuação 1
1 comentário:
What if its a new one without a battery?
por
Remove the battery if you can, and if the device has a CMOS battery, remove that for 10 seconds. Replace both.
If you still get the same results, you may want to try replacing the hard drive, as I see this as a plausible reason for these symptoms.
Pontuação 0
2 comentários:
How do I for sure get it unstuck
por
This is a new CP how can the hard drive be bad
por
Control + Alt + Delete and restart.
I’ve had this problem a couple of times, but this always fixes it.
Pontuação 0
Adicionar a sua resposta
Connor Watkins será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 34
Ao todo: 28,300
