Ir para o conteúdo principal
Guias de reparo e informações de desmontagem para laptops fabricados pela ASUS.
Correcting upside down display
My cat somehow changed my display upside down while I was sleeping. This has happened before, and I was able to adjust it back by Ctrl+Alt+Up Arrow, however; this is working this time. Keyboard is not locked. Any suggestions?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Hi,
Right click on the desktop background, click on Graphics Options, then Rotation, then Rotate to Normal.
If you have Intel Graphics installed , right click on the desktop, click on Graphics Properties. Select Advanced Mode click OK. Look for the Rotation settings, on the right side down near the bottom, select Rotate to Normal.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Appreciate the help!
por
@tore37 you did not tell us what OS you are using. Right click on your screen click on screen resolution. See what it says for orientation. It may be at something like landscape flipped etc. Sometimes reinstalling the driver for your video and then retrying the Ctrl+Alt+Up keys may work again.
Pontuação 0
1 comentário:
Thank you so much for your quick response! Will try when I get home from work ;)
por
Adicionar a sua resposta
Julie McNeill será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 23
Ao todo: 7,131
