My USB port stopped working
My USB port has stopped working is there any way that I can fix it?
Esta é uma boa pergunta?
You may need to replace the USB port. This is fairly easy to do. It is soldered onto the circuit board with 6 contact pins. If you do not know how to solder iFixit has a great guide here. Como soldar e dessoldar contatos
Make sure the soldering iron reaches temperatures higher than 300 degrees Fahrenheit. Hope everything works well for you.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 322
