Ir para o conteúdo principal
An affordable dual mode notebook with a 300° rotation and touchscreen display.
6 Perguntas Visualizar todos
I spilled some coke on it but its working fine
A week ago i spilled some coke on the left side of my lenovo flex 3 , i turned it upside down for about an hour , i could'nt notice any coke coming out. but its working perfectly fine, would it create problems for me later on or am I on a safe side now? because as i mentioned the spill happened about a week ago
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
As you know liquids and electronics and electricity are not a good mix.
The liquids causes corrosion and provides circuit paths for the electricity which were not in the laptop's operating design and could damage the components.
First do not turn on your laptop and then you need to remove the battery as soon as possible from the laptop to minimize further damage.''
Then you need to dis-assemble the rest of the laptop and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and liquid. Do not use "rubbing alcohol" as in some cases this is only 70% and is not as effective. If you do check the label to verify the amount
Here is a link that in general, describes the process.
Electronics Water Damage
You may possibly have to replace the battery as it is very hard to recover a battery from liquid damage.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the laptop might possibly work correctly again.
Here is a link to the service manual for your Ideapad.
Starting at p.33 it details the procedures on how to dis-assemble and remove components from your device.
https://download.lenovo.com/consumer/mob...
If the above is too daunting a task, take it to a reputable, professional laptop repair service and ask for a quote.
Either way if you decide to do this or to get someone else to do it do it sooner than later.
Update (10/27/2016)
Hi,
The laptop needs to be opened and visually inspected for any signs of corrosion. If corrosion has occurred, it does not go away by itself. It needs to be removed by cleaning it in the correct manner to prevent problems that may manifest themselves in the future,
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Shoaib Khan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 337
