Ir para o conteúdo principal
Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
How can I repair/replace the jack input?
I damaged my jack input by tripping over the cable, and now I only have the left side of the stereo. I'd like to replace the jack input or to repair it, maybe with a soldering iron.
Thanks !
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
You can replace the headphone jack, your challenge will be the soldering and locating the part. If you have a hot air station, you could replace it fairly easily. It's also possible with a good soldering iron, flux, and a solder sucker or wick.
If you're comfortable with the soldering part, you still need to locate the part. You can either look on aliexpress, as they have some headphone jacks listed for the XPS 13, or you could look on eBay for a XPS 13 motherboard thats broken, and transfer the headphone jack from that board.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Malo Herry será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 12
Ao todo: 765
