Ir para o conteúdo principal
O Samsung Galaxy Tab 4 7.0 Sprint é um tablet Android com tela de 7 polegadas e 1280 x 800 pixels. Ele possui conectividade Wi-Fi e acesso à rede móvel 4G LTE da Sprint.
Why is the touch screen not responding?
The touch screen is not responding. I tried closing all the running programs and restarting the tablet and the screen is still not responding.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
If freeing up resources and re-initiating your tablet didn't solve its touch issues, then you might need to open it up to take a look inside. It may be that the connection between the screen and the tablet's motherboard is a bit loose and simply needs to be re-seated. If these symptoms began after a drop, or after the tablet was exposed to water, you may need to replace the LCD display. You can head on to your tablet's troubleshooting page for more info on this matter.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Valentina Franco será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 339
