Ir para o conteúdo principal
A primeira geração do Honda CRV, produzida de 1995 a 2001.
Fuel pump needs replacing.
My car is running but hesitates when I give it gas, then it surges. I believe it is the fuel pump. Would like to do it myself. Is it really difficult?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
I would check for vacuum leaks before condemning the fuel pump.
por Compartilhar
Adicionar um comentário
3 respostas
Pergunta mais útil
@paintmarrow not to complicated. Here are the instructions:
Imagem
Imagem
Esta resposta foi útil?
Pontuação 1
1 comentário:
Disconnecting the car battery before replacing the fuel pump is also a good idea.
por Compartilhar
Check EGR and gas filter
Pontuação 0
1 comentário:
Did the replacing the fuel pump work?
por Compartilhar
So i have a 01 honda crv… when i turn car on it idels crazy. Then sometimes my rpm gage will work sometimes not. It stoped working when i tried to give my car gas. It was stuffering like it was trying to shut off as i was going down road. Sometimes it will die when i come to a stop. I gave to put it in neutral and keep foot on gas. Then there are days she runs great . Put in new filter. And a idle air control sensor. And its still doing it. It didnt start this until i got timming belt done. The shop has looked at it and its not because of the timming .. so please help what could it
Pontuação 0
Adicionar a sua resposta
Tamara Rose será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Ao todo: 2,122
