Ir para o conteúdo principal
The Acer Iconia W3-810 is a Windows tablet with an 8.1” HD screen and an Intel Atom Dual Core Z2760 processor.
9 Perguntas Visualizar todos
Why can’t my tablet connect to WIFI?
I can not get my tablet to connect to the WIFI
Esta é uma boa pergunta?
Pontuação 3
1 comentário
It not the network as i have reset it and all other devices have picked up the network
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi @Michael Emery,
Can you access the network when the tablet is right next to the router?
If so try disabling the tablet’s WiFi’s minimum power consumption setting. Go to Device Manager > Network Adapters > right click Broadcom Wireless > Properties > Advanced > minimum power consumption and see if that helps. (not quite sure if it is called minimum power or something similar)
Esta resposta foi útil?
Pontuação 1
Make sure the WIFI is enabled. If this does not work perform a hard reset. If the problem still persists check your router or modem to see that they are properly connected.
Pontuação 0
Adicionar a sua resposta
Kyle Coker será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 563
