Ir para o conteúdo principal
O Honor 3C é um smartphone Android produzido pela Huawei, lançado em dezembro de 2013 na versão 3G, abril de 2014 na versão 4G e agosto de 2014 para o 3C Play. O Honor 3C pode ser identificado pelos números de modelo H30-T00 e H30-U10.
How can I fix the mic
The microphone on huawei honor 3c doesn't work
I can't record my voice
When I make a phone call no one here my voice but I here them very good
My phone fell on the ground to day
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Connect the earphones with the microphone attachment and either make or receive a call.
If your voice can be heard then the voice transmission circuitry of the phone is OK but there is a problem with the microphone.
If your voice cannot be heard then there is most probably a problem with the systemboard in the phone.
Here is a link to a video which shows how to disassemble your phone.
https://www.youtube.com/watch?v=IWwZLrHq...
Unfortunately it doesn't show the microphone, but if you have proven that the problem is with the microphone and wish to investigate to see if you can spot the problem, here is a link that shows what the microphone looks like. It should be positioned near the voice input hole on the bottom of the phone.
https://www.aliexpress.com/item/2PCS-Ori...
If opening and checking your phone seems to daunting then I suggest that you take it to a reputable, professional phone repair service and ask for a quote for a repair.
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
Lam será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 12,555
