Ir para o conteúdo principal
Pentium M 1,6 GHz, 512 MB de RAM, HDD de 40 GB
SSD Hard Drive Kit
I have an old IBM ThinkPad T41 with a missing hard drive. I have an SSD drive, but I don't have anything to hold it in place in the hard drive slot. What items would I need to purchase ?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I don't know how crazy you want to get, but some good carpet tape will hold it :)
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
You could purchase a laptop HDD caddy.
Most SSDs should fit into the caddy with the screwholes lining up.
Here is a link that shows how to remove the HDD from a T41 laptop. Just reverse the procedure.
http://www.laptopinventory.com/LaptopInv...
Here is a link, from just one supplier, that shows what a caddy costs and looks like. There are a lot more suppliers if this one doesn't appeal to you. Just search online for Thinkpad T41 HDD caddy.
http://www.tmart.com/Hard-Drive-Cover-Ca...
You may have to pack out the SSD a bit if it is thinner, to support it (even with the screwholes lining up) , so as to not place too much stress on the connectors. Any foam or rubber type material should be suitable.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Brian será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 23
Ao todo: 1,237
