Ir para o conteúdo principal
A Kenmore 90 Series é uma lavadora fabricada pela Kenmore.
How do I remove top of machine?
How do I take top off to reattach part that goes down to initiate draining and spinning. The lid has to be closed to initiate this feature. I stupidly overloaded and that piece came loose.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
Marsha, If it was the lid switch that came loose check the link below easy to follow instruction/video to show Kenmore washer cabinet removal, 2nd vid. shows lid switch replacement.
https://www.youtube.com/watch?v=vogysB7X...
https://www.youtube.com/watch?v=MFsvLiuT...
Esta resposta foi útil?
Pontuação 2
@marshas with the top loader you usually remove the whole cabinet. Take a look on here. There may be a different way for your issue but we need to have the exact model number and maybe a few images of the part that came loose. Use this guide to post images so we can see what you see.
Pontuação 0
Adicionar a sua resposta
Marsha será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 22
Ao todo: 11,168
