Ir para o conteúdo principal
ZTE Zmax Z981 charging port
Hello guys I've been looking !&&* n' high water for a video or fixit for this model, i need to repair charging port i can find things close to this model such as charging ports, repalcement screens but nothing for this actual model number,please help. if anyone needs any information please contact, thanks.ZTE Zmax
Esta é uma boa pergunta?
Pontuação 0
2 comentários
If anyone can't help can i at least get a pointer to someone who sells cell phone parts.
por
Hi, @chipsjoint
I agree, it is very difficult to find any parts relating to this model. Suggest perhaps if you have the phone open that you take pictures of the charging port, (is it actually damaged or just broken off the board? If just off the board and you haven't got the tools then any reputable phone repair service should be able to resolder it back on) and then see if you can image match using Google to give you information regarding the exact type etc.
Also you might wish to check if there is any 'information' stamped on the port itself. If so it might give you a clue. Just google the information (nothing about port or ZTE -that will just skew the result) and see if the results are worth following.
por
Adicionar um comentário
3 respostas
Pergunta mais útil
ZTE ZMax Pro (Z981) Disassembly
here you go man
Esta resposta foi útil?
Pontuação 2
Wonderful! Now instead of getting it replaced under manufacturer warranty for $30, I can take it apart and get rid of this piece of SH@#. It will be an enjoyable task. What a waste of money, just when I thought those of us with low incomes were getting a real break from MetroPCS. So much promise, so many problems.
Pontuação 2
try ebay
type this in zte xmaxx pro Z981
and you will find some parts
and other things
Pontuação 1
Adicionar a sua resposta
Chip Amaker será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 2,188
