water damage dosen't power on
walking from highway for home suddenly heavy rain came and my device has been wet in the water
Esta pergunta é pertinente?
Hi,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components
First you need to remove the battery from the phone.
Here is a link that shows how to do that.
http://www.etradesupply.com/blog/how-to-...
Then you need to clean and dry the electronics using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water.
Here is a link that, in general, describes the process.
You will probably have to replace the battery as it is very hard to recover a battery from water damage.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work again
Esta resposta foi útil?
Hi @ Ramansingh Manhar,
Did you mean a Motorola E6s?
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available from electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you have to use it, check the label to verify the amount of IPA it contains. The higher % IPA the better.
Here is a link that describes the process.
Also be sure to remove the LCD screen flex cable from its connector on the systemboard and clean the cable end and the connector with IPA in case water got in there as well.
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
I cannot find a dis-assembly guide for your model phone. Here’s one for a Motorola E5 which hopefully may be close enough to be of some help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 29
Duração total: 13,359
2 comentários
Sir, my Motorola 6se accidently drowned into water. Due to this it hangs time and again, takes too much time in charging and it's sensor is not working. Kindly guide me what to do, only a month or so has gone after buying, my hard earned money is behind it!
por Ramansingh Manhar
my moto g4 plus dropped in water repair center said mother board is not working, but when i connect charger with it down side light blinking, so my screen is wroking or not.
por Niraj Kumar
