Ir para o conteúdo principal
O BLU Vivo 5 é um smartphone Android produzido pela BLU, uma empresa americana de eletrônicos de consumo. O 5 foi produzido através de uma parceria entre a BLU e a Vivo Communication Technology Co. Ltd., uma empresa chinesa de tecnologia. O BLU Vivo 5 foi lançado em fevereiro de 2016.
blu vivo 5 charging problem
Why wont my blu vivo 5 charge? I plugged it in the charger, and it takes a day to increase by 1%. And it loses charge very quickly when unplugged.
Esta é uma boa pergunta?
Pontuação 4
1 comentário
vivo5 needs a strong charger. i use samsung fast adaptive charger that produce both 5v and 9v and 2A amperage
por Compartilhar
Adicionar um comentário
2 respostas
Solução escolhida
Hi,
Is your phone still relatively 'new'?
Verify the purchase date on the sales receipt for the phone and if it is less than 12 months old, consult the warranty documentation that came with the phone as what you need to do to make a claim for a warranty repair or replacement.
Esta resposta foi útil?
Pontuação 4
5 comentários:
I got a replacement device through warranty and it has the same problem as the original
por Compartilhar
Hi, Sounds like it's not a very good model doesn't it. Get this one replaced as well or see if you can get a different model under warranty of course!
por Compartilhar
please change my mobile
por Compartilhar
I had the same problem with 2 brand new Blu Vivo 5 devices, but it has turned out that the problem were in the charging cables (both brand new) and not the phones... So I just bought different charging cables on the Amazon (Type C Cable 6ft, X-EDITION Gold-Plated Durable Braided ( USB-A 2.0 to USB-C Male) Fast Charger Cord for LG G6/G5, Moto Z/Play, BLU Vivo 5 XL, Nexus 5X/6P, Samsung Galaxy S8 Plus, (Gray, Gold) 2-Pack) and ta-daaa! No more problems with that! Works like a charm! Just buy new charging cables.
por Compartilhar
I also have the same problem. The charger cable that comes with the phone is garbage and replacing it with a higher quality one will fix the problem. Make sure you get one that is rated USB 2.0 and higher to ensure the proper charging speed. I use the Anker 6ft USB 3.0 type-C cable.
por Compartilhar
My blu vivo xl is 1 month old.
Same issue.
Pontuação 4
Adicionar a sua resposta
benarde123 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 21
Ao todo: 9,230
