O rádio-relógio Sony ICF-C1T foi fabricado para que, em caso de queda de energia, você tenha a tranquilidade de que o dispositivo continuará funcionando para nunca perder um compromisso.
Hi, Try resetting the device by removing all the power from it. By that I mean unplug the device from the power outlet and also remove the CR2032 coin cell battery as well. Then press the enter/time set button for about 10 seconds to discharge any residual power in the device. Restore the AC before reinserting the coin cell battery (be careful that you insert the battery the correct way +ve side up).
You will lose the time on the clock but since it is not working properly anyway you don't have much to lose by trying the above.
Bob Arn just to clarify. What projector? You selected a alarm clock/radio as the device.
por oldturkey03
The clock projects the time on the wall. I meant to say that no buttons on the clock radio respond.
por Bob Arn
por jayeff
