Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Replacement screws, how do I measure them?
Hello guys, this time I am here to know if there is an easy way to measure the screws in a set of replacement screws for iPhone 5s.
Thing is I only need the ones holding the home button bracket (1.4mm #000 phillips); the ones holding the battery connector bracket (1.6mm #000 phillips); the ones holding the front panel assembly cable bracket (1.7, 1.7, 1.3 and 1.2mm #000 phillips); the ones holding the earpiece speaker bracket (4.0 and 2.3mm #000 phillips); and the one securing the back of the display assembly to the LCD plate shield (2.7mm #000 phillips).
So I need to know which one is which.
Any help?
Thanks.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
@caraneday looks like they have been measured by the total length. The only way to measure them properly is by using a vernier caliper. Not an expensive one time investment....
Esta resposta foi útil?
Pontuação 1
5 comentários:
@oldturkey03 thanks, I'd thought the same but... how accurately would that be? I mean, there are 1.2 and 1.3mm; and the caliper has an error range, so a 1.2mm might be seen as 1.3mm right? :(
por
Sure it could but that's a bit high for a vernier error rate. If that would happen then all of them would measure longer. It's never easy to get all of it right when we did not have a chance to sort the screws during dismantle or if they get mixed up. Toughest part of that job......
por
@oldturkey03 any brand you suggest? a digital ideally :P
por
Not sure where you are locatesd I'd go with a digital rweadout since that will speed up your work and you do not have to struggle with either metric or imperial
por
@oldturkey03 thank you so much!
por
you’ll need to pay attention to the screw diameter. and a digital caliper such as Harbor Freight sells will save you a lot of pain an guessing.
Pontuação 0
Adicionar a sua resposta
Carlos será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 1,667
