Ir para o conteúdo principal
Encontre detalhes de reparo e informações adicionais sobre a geladeira GE DFE29JSD, um modelo de 2012 com freezer inferior, acesso por gaveta e porta, e capacidade de degelo automático. Esta página cobre informações para números de modelo que correspondem ao padrão DFE29JSD****.
GE DFE29JSDDSS What does code sa66 mean?
what is the problem??? display lights keep going around in circles??
code sa66 keeps coming up.
Esta é uma boa pergunta?
Pontuação 11
13 comentários
New appliances have a mode called sabbath mode. It turns your advanced features off for the weekend. To exit sabbath mode or SA 66 push and hold light and lock simultaneously for 3 seconds, or for some models it's alarm and light for 3 seconds.
por
And WhaLa it fixed the problem and back on line.
por
WTH! Sabbath mode, REALLY! I was cleaning the frig and the panel went out. It's taken me 5 days of pulling my hair out to find out the code that kept flashing (SA 66) was something I turned on. Don't know how I did, but it did. Pressed the unlock and light button and know I don't need to by a control circuit board to find out that I didn't need it. TY Frank!
por
THANK YOU. Had to unplug it and then plug it back in, wait for the screen to light up, and then press and hold Lock and Light. You saved me a lot of time and money not having to have a service technician come out!
por
thank you for quick fix
por
Exibir mais 8 comentários
Adicionar um comentário
6 respostas
Solução escolhida
Most new appliances have a Mode called sabbath mode. It turns your advanced features off for the weekend. To exit sabbath mode or SA 66 push and hold light and lock for 3 seconds, or for some models it's light and alarm for three seconds.
Esta resposta foi útil?
Pontuação 16
22 comentários:
Thanks Frank! This worked for me!
por
Thanks this kept my husband from taking things apart.
por
This worked for me! How it got in Sabbath mode I have no idea
por
Much appreciated. Two thumbs up for Frank.
por
Absolutely fantastic. Thanks for the fix!!!
por
Exibir mais 17 comentários
northerncarrs not sure about the SA but the 66 errorcode is a failed door icemaker rake motor test. Unplug your fridge for a while and then plug it back in, to see if a reset will work.
Pontuação 2
1 comentário:
Thank you so much!!
por
Wife cleaned the fridge… it died (lights & control panel) but continued to cool. Unplug then plug back in after a short time no change but SA66 flashed once on control panel. Pushed lock and light on panel and POOF all came back on! Thanks Guys GE Fridge Model dfe28jmkes
Pontuação 2
8 comentários:
that is exactly what I did....lol. I wiped down the fridge and the next time I went to open it, the lights were out. thought great what the heck is going on. husband got all upset because the fridge is only a little over a year old. We did the same as you did, but then took it one step further and started re-setting breakers and that's when we saw the error code....and now we are here. LOL We've never known a religious fridge before.... :-)
por
This worked for us!!! The tip about unplugging and plugging back in for the "window of opportunity" was SO helpful!! Thanks!!!!
por
Thank you so much! Yes holding down the lock and light buttons worked!
por
Thank you! I did the same thing as a previous post, I was cleaning and didn't even know I did it! WHY is this even a thing???
por
Thank you, Frank! You saved us a lot of money. My refrigerator was working within seconds of me reading your post!
por
Exibir mais 3 comentários
Oh the solution that worked for us on our GE Profile Model PYE22KSKBSS (2016) was Unplugging for 10 minutes, and then Holding the LOCK & LIGHT button simultaneously for three seconds.
Pontuação 1
Holy cow you saved me a ton of money! I cleaned the refrigerator ice dispenser and all of a sudden all the lights went out. My husband took apart the entire back to see if he could tell what was going on. I started looking at new refrigerators and almost chocked because they were $2900 to $3400 dollars. I was sick trying to figure out where I was going to get the money. I started searching around and finally ended up on this post. Low and behold your solution worked. Thank you so much. I am very grateful.
Pontuação 0
1 comentário:
por
This also worked for us. I thought we were in for a $500 repair for sure. I tried unplugging the refrigerator over and over. I finally noticed the sa66 error code and looked that up on the internet. Low and behold, a real solution. Finally the internet became a great resource for an answer. Thank you Frank. You deserve the Nobel Prize for really helping folks like us!
Pontuação 0
2 comentários:
Did you need to unplug it for awhile AND do the light/lock hold?
por
Unplugging the fridge just lets you see the error code for a few seconds. Pushing the lock and the light buttons simultaneously for 3 seconds turns off the sabbath mode.
por
Adicionar a sua resposta
northerncarrs será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 51
Ao todo: 28,877
