Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
My phone is unresponsive
I had this iphone 5c for about 2 years and today i dropped it and it landed on its back. The screen went black and wont display anything. I tried useing the trick where you hold the home and power button, but it didnt work. I tried to connect my phone to my computer but nothing shows upon my computer, but my computer does make a sound when i plug it in and out. I kind of feel some heat in my phone. TOday i just tried to connect it to itunes and itunes recognizes it but i can do anything on itunes with it. My phone makes no noise anymore and I dont know how to fix this issue, like what do i need to buy.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Sounds like you most likely did some damage to the board itself with the drop, but you can always make sure by replacing the screen if it is now connecting to iTunes. Here is the guide to replace the front panel assembly and it also has links to the parts and tools you need. Be aware that you will need to transfer the home button as well as the front facing camera.
Before you do that though, what kind of message did you get when it connected? That you needed a passcode to do anything?
Imagem de Replace a scratched or cracked front glass digitizer panel or malfunctioning 4.0 inch 640 x 1136 pixel IPS LCD compatible with the iPhone 5c.
Produto
iPhone 5c LCD and Digitizer
$39.99
Imagem de iPhone 5c LCD and Digitizer
Guia
iPhone 5c LCD and Digitizer Replacement
Nível de dificuldade:
Moderado
30 minutes - 1 hour
Imagem de iPhone 5c Home Button
Guia
iPhone 5c Home Button Replacement
Moderado
1 - 2 hours
Imagem de iPhone 5c Front-Facing Camera and Sensor Cable
Guia
iPhone 5c Front-Facing Camera and Sensor Cable Replacement
Moderado
40 minutes - 1 hour
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
muning será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 87
