Ir para o conteúdo principal
The 2008-2012 Ford Escape features a revised front and rear fascia and restyled LED tail lamps.
Moderate windshield wiper speeds not working.
I have a 2010 Ford Escape XLT V6 4WD, and some of the windshield wiper speeds do not work. Only the moderate speeds. I have slow full speed, but none of the others work. I've been able to get by, with treating the glass with Rain X solution but I really want to have all my speeds. I think it's the switch, because it does work when you use the spray fluid button.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
You can try changing the windshield wiper/washer switch. It will involve taking apart the steering column trim. If you don't think that is in your capability, find a good local garage and they can help you out. Good luck!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Sean Ryan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 379
