Ir para o conteúdo principal
Cut (Crop )image up negative down normal
Plz suggest me how to repair my Tv.
Last 2 dy my Tv screen cut image .
Tv up side like negative screen & down side Normal so plzz
what's problem...
My tv num :panasonic tx-32lx70c
Update (06/06/2016)
Imagem
See attached file and plzz suggest
Esta é uma boa pergunta?
Pontuação 2
3 comentários
@mayur could be a panel issue. Just to verify your image appears cropped, upside down and inverted? Post some images of what you see with your question. Use this guide Adicionar imagens a uma pergunta já existente for that.
por Compartilhar
@mayur the grey on the bottom of the TV's display or is that just on your picture?
por Compartilhar
That's just on picture,
But top side defect( black sheds ),
See channel name line
Cut he face..
por Compartilhar
Adicionar um comentário
1 resposta
Pergunta mais útil
@mayur unlikely that this would be caused by a bad LCD or a bad driver logic. I would suggest that you start with your settings first. Make sure that you have things like "mirrored" etc. not accidentally turned on. If your menu has a factory reset, try that.
If you are 100% sure that your settings are right and that a reset did not resolve this, you'll have to open up your TV and take a look at the boards. Check for obvious damage and post images of those boards with your question.
Esta resposta foi útil?
Pontuação 3
3 comentários:
What's Problem My Tv.
Plz Tell Me Details...
I hve open My Television And Clean Dust Also.
Bt No Idea What Can I.
So Plzz Explain Me..
This Problem Faced Last Two Weeks .
Power Shut From Electricity .When
Power Come That Time To Till Date This Problem Faced..
I Don't Understand What's Problem on Television..
por Compartilhar
@mayur Have you done a complete reset yet? Go into your TV's setup menu
por Compartilhar
Which side show reset menu
por Compartilhar
Adicionar a sua resposta
mayur será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 21
Ao todo: 739
