Ir para o conteúdo principal
They Pyrus Digital Video Camera Recorder is a 24.0 mega pixel camera and video recorder. It has USB and HDMI support plugs as well as an 18x zoom and SD port.
My camera wont turn on and it wont charge
When I have my camera plugged it to charge the camera does not turn on, I can not get my camera to turn on. What could be wrong??
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The most likely causes for your problems are that something is wrong with the charger,charging port, battery, or it could be something wrong with the display screen making it appear to be off.
You should probably check the Troubleshooting Guide for help. It covers both of these problems. Also if it is just the screen then the Display Screen Replacement Guide could help your problem.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Danielle Hadaway será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 1,176
