Ir para o conteúdo principal
The Nintendo GameCube Controller DOL-003. Released November 2001, compatible with Nintendo GameCube, Nintendo Wii, Nintendo Wii U, and Nintendo Switch. Repair for this device is straightforward and requires only common tools.
How can I replace the "electronic" joystick component?
My controller's electronic joystick component is loose and goes rogue when I plug it in, how do I obtain the electronic part and how do I solder it to the controller's pcb?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@gio_ex that will depend on which part it is. Take some pictures and post those with your question. Use this guide for that. Most of the part requires soldering and use these guides to familiarize yourself with the process. After that you need to practice a lot.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Giovanni será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 347
