knobs crackle and pop
old peavy amp.. knobs crackle and pop
Esta é uma boa pergunta?
The pots (potentiometers) are dirty.
1. Get a can of deox it or other electronics cleaner.
2. Unplug amp!
3. Get inside of amp and check on the back side of pots. If there is a small hole
spray some cleaner in there and rotate knob back and forth frpm 0 -10 several times.
If there is no hole, Remove knobs and spray down the shaft in the front give it a minute to get down in there then rotate knob several times. do this to every pot.
4. Put back together and Jam
Esta resposta foi útil?
Probably needs new pots (potentiometers). If you're not confident changing them yourself, ask at the local music shop - they will almost certainly know someone who you can pay to do this for you.
Alternatively, you could attempt to do it yourself - or just clean them. There are many guides on how to do this, e.g, this one: http://www.instructables.com/id/How-To-C...
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 28
Ao todo: 1,410
1 comentário
FYI - you question is not very good as it leaves a lot unanswered that requires us to guess and ask more questions that we answer. It is like saying "my car runs funny"
por bill Compartilhar
