Cable chewed in half
My sons cat chewed the cable in half. Can it be fixed or is there a replacement part I can purchase ? Thank you
Esta é uma boa pergunta?
This will fix it: https://www.youtube.com/watch?v=ulN-_FWe...
Esta resposta foi útil?
Knew that was going to be solution when I read the problem
@masonbubba that will depend on where it is split. You can remove the insulation from both sides of the cable end, then solder those ends together and apply insulation after each soldering.
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 19
Ao todo: 847
