Ir para o conteúdo principal
Este tablet Android multifuncional foi lançado em maio de 2013. Ele possui uma tela LCD de 7" com resolução de 800x480, processador dual core e suporte para até 32 GB de memória adicional.
Why is the touch screen not working?
I recently dropped my tablet, it still turns on and charges fine but when ever i try to unlock it i the touch screen isn't responding
Esta é uma boa pergunta?
Pontuação 2
4 comentários
Are there any visible signs of damage on the screen?
por
No visible signs of damage
por
Did not drop mine
por
I’m 12 and this is bugging me because I never dropped it but it was in my backpack and it cracked
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi @myrnar ,
If the LCD display screen still works but not the touchscreen the fall has either loosened the digitizer (touchscreen) cable connection to the systemboard or the digitizer is faulty and needs to be replaced.
Here is a link to the ifixit guide to the Substituição da tela do Trio Stealth G2 which may be of some help (I hope your tablet make and model is this one, as you haven't said otherwise).
Here is a link to just one supplier of the replacement part. It is not a recommendation to use them, it is shown to give an idea of the price. There are others online that may suit you better. Just search for Trio Stealth G2 Hype digitizer part for results.
Hopefully this is of some help.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Ramiro vera será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Ao todo: 1,518
