Ir para o conteúdo principal
Versão simplificada e de custo menor do chipset XFX 680.
RAID 0 gone bad.
any ideas to get a raid 0 array working again? the drives are fine and all the data is on them, but raid doesn't want to recognize them. someone suggested rtools, but a demo version only lets you recover 64kb files. key? other options?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
did I mention this is for an XFX board?
read: running Windows 7.
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
If the RAID set is broken, yet you can read the data, your best option is to copy off what you can/need.
The only way I know to get a broken RAID 0 set back working is to set it up as new - which means the existing data is going to be erased.
RAID 0 is all about speed and performance - there is NO data redundancy... Depending on how your RAID controller and RAID 0 set was created, you may only lose files split across the drives (JBOD mode). If your RAID 0 was in Striped mode, you will probably need pay for something like rtools.
Esta resposta foi útil?
Pontuação 1
3 comentários:
that's what I figured, I'm trying to decide if rtools is worth it because I don't actually remember what's on them. If I knew, I'd be able to decide. Oh you, impasse!
por Compartilhar
por Compartilhar
R-Studio is a great thing. You will certainly be able to use it for other things beside this problem.
por Compartilhar
Adicionar a sua resposta
tabormeister será eternamente grato(a).
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 13
Últimos 30 dias: 33
Ao todo: 4,885
