Ir para o conteúdo principal
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
773 Perguntas Visualizar todos
Question about foam stickers and plastic cover on battery
Hi
I have a simple and maybe trivial question. I have been following this guide: MacBook Pro 13" Retina Display Early 2015 Heat Sink Replacement
When I start to assemble my macbook again, am I supposed to put the foam stickers in step 8 and the plastic cover in step 4 on again? And if they are not sticky anymore, what do I do then?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I wouldn't worry about the battery sticker. The foam gives some impact protection. I'd put the on and hit with just a little heat from a hot air gun or even a hair dryers, not to much.
Esta resposta foi útil?
Pontuação 5
2 comentários:
Thanks i'll do that.
por
By any chance you know where I can get replacements for the foam stickers?
por
Adicionar a sua resposta
Anthony Le será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 312
