Lost of internal memory chip
i lost internal memory chip. screen is showing just light with dots, can it repaired i don't want to lose my data.
can data recovered ?
Esta é uma boa pergunta?
@sudhan, you can only recover your data if your phone still responds and can be found as a device when you plug it into a computer. There is no other way to recover from the memory IC's by the normal DIY'er. There are companies out there that can do it but that will cost $$$$$
Esta resposta foi útil?
i also connect my phone with computer but not deducting internal drive.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 62
7 comentários
if you can attached a screenshot it would be much helpful to diagnose your problem... and if the internal mem is lost you have probably already lost your data bro..
por Abdul Galib
its not working that i can get screen shots
is there no any way to get back data ?
por Tanweer
can i know what is the cause to happen this thing. (damage of internal memory)
how to prevent from it
por Tanweer
@sudhan, when you say you lost the memory chip, what are you referring too? Lost as in physical broken? Lost as in cannot access?
por oldturkey03
it was working normally but suddenly screen become white with dots in it, i was thinking Lcd was gone but when i contact the person for repairing he told me your Lcd is ok this is internally memory chip problem it will required to change with new one , i did't repair due to my data, i need it in any cost.
por Tanweer
Exibir mais 2 comentários
