Ir para o conteúdo principal
Lançado em 25 de fevereiro de 2013. Tablet de 10,1 polegadas com sistema operacional Android, processador Quad Core ARM Cortex A-7.
sim card does not read
Says no sim card when sim card is in the reader
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Hi, Have you tried a different known working SIM card in your Tab? Have you tried your SIM card in another device to prove that it is working?
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
Hi @iran9374166620
Have you tried another known working, network compatible SIM card in your tablet to see if it works?
Have you tried your SIM card in a known working, network compatible device to see if it works?
Here is a link to the service manual for your tablet.
It shows the pre-requisites and procedures necessary to gain access to the components in your tablet.
https://download.lenovo.com/consumer/mob...
On p.42 item #8 it shows the part number for the SD Card/SIM card module. Check the number on your particular module and then search online using just the number, for suppliers of the part. It is not cheap!
Here is a link to just one supplier of the SD Card/SIM Card module to give you an idea of the cost.
http://electrical-components.com/lenovo/...
Hopefully this is of some help.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Lindiwe Msibi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 17
Ao todo: 1,686
