Ir para o conteúdo principal
Released on September 25, 2013, The Galaxy Gear (model no. SM-V700) is one of the first devices in Samsung's wearable lineup.
20 Perguntas Visualizar todos
How do I change the gear smartwatch band?
I broke the camera lens and bought a new watch band. How do I change it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Most watches have a pin that runs though the end of the strap and attaches via a spring mechanism to the watch itself.
Although the following guides aren't specifically for the Samsung Galaxy Gear, they might help you understand the technique and tools you can use to change the bands on your particular watch:
How to Replace a Watch Strap
Pebble Steel Watch Band Replacement
Let us know if this helps!
Imagem de Watch Watch Strap
Guia
Nível de dificuldade:
Fácil
10 minutes
Imagem de Pebble Steel Watch Band
Guia
Fácil
5 minutes
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Cheryl Klimack será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Ao todo: 1,121
