Ir para o conteúdo principal
Quadricóptero com estabilizador de câmera pré-instalado, câmera de vídeo 4K e transmissão de vídeo sem fio.
Remove Gimbal Clamp Error
I have had my drone for about a year now. Today I was flying it in one location perfectly fine, shut it off, drove to a new location and turned it on. On my phone it had an error that said "Remove Gimbal Clamp," as well as a beeping sound that came from the gimbal. I did not have the gimbal clamp on and no matter how many times I took the battery out or put a new one in, nothing worked. What do I do?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Did you ever fix this problem? I'm stuck with the same issue myself.
Esta resposta foi útil?
Pontuação 0
Sometimes I have that problem in my Phantom2 Vision Plus.
Please contact me if you have one solution. Thank you.
Regards,
Carlos Sousa
Pontuação 0
Adicionar a sua resposta
Matt será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Ao todo: 1,878
