Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2375 Perguntas Visualizar todos
Why does My iPhone give me a buzzing noise?
Hi! I am here cause I am freaking out right now and I'm sure someone here can help me out. So I got a new Iphone 4 a few months back but it's still like brand new. And then one day a huge incident happened so I had to give it to a store and they pasted this Plastic-ish glass thing on top, like a screen protector but a hard one. The real incident was that my lil bro dropped my phone and something in the phone changed but anyways it was like the first time I dropped it and it already got damaged and I wasn't pleased but after buying this screen protector thing everything was back to normal and I bymistakenly dropped my phone a few days ago and I freaked out but like nothing happened thanks to the protector. So the real prob, When I record a video on my iphone camera, and then open the gallery and watch the video, it makes no noise except this buzzing noise. The buzzing noise is like high-pitched btw. So the reason I freaked out is that i dint like this happening to my new iphone. And I hope its not something big to repair but like I saw on this website that it can be because of any screen protector/case and I checked my phone (can't believe I was this stupid) and In a minute I ripped off the screen protector:( And then I checked it again, I mean I recorded a video and it was still the same thing (Stupid idiotic website). I tried blowing on the hole stuff and all but technically I am not a genuis and I assume that most of the answers are to remove the parts of the iphone and reasemble or something but I really can not do that cause I'll end up making it worse. Any way I can fix this? And fiy this problem dint exist before and it is not because my brother dropped the phone, but most importantly it is really hard to protect this phone from my little brother and now that the screen protector is off, I need a solution quick and then I need to put on another accurate screen protector. Please help. xxx
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Where is this noise coming from? This sounds like it's coming from the microphone. Try playing some music and see if you're hearing that noise. If not then try hearing it from recorded audio from the Voice Record app. If you hear it through voice record app. Then your bottom microphone is most likely at fault.
If you can hear it while playing music then the loudspeaker is at fault.
iPhone 4 Dock connector part:
[produto vinculado ausente ou desativado: IF182-009]
How to replace Dock Connector (Charger port assembly)"
iPhone 4 Dock Connector Replacement
Here is the part for the loudspeaker:
[produto vinculado ausente ou desativado: IF182-013]
Guide on how to replace loudspeaker:
iPhone 4 Speaker Enclosure Replacement
I couldn't find any parts on iFixit where they have the iPhone 4 charging port flex cable assembly which comes together with the bottom microphone built in.
Imagem de iPhone 4 Dock Connector
Guia
Nível de dificuldade:
Difícil
45 minutes - 1 hour
Imagem de iPhone 4 Speaker Enclosure
Guia
Difícil
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Abdul Haadi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 64
Duração total: 11,031
