Ir para o conteúdo principal
Sony’s 20.1 megapixel camera designed to capture still images and video recording. Model number: DSC-W800.
11 Perguntas Visualizar todos
Why will my device not power on?
Why won't my Sony Cyber-shot DSC-W800 power on? When pressing the power button nothing displays on the screen and the device seems to be unresponsive.
Could this be a battery issue or something more serious that would require repair?
Esta é uma boa pergunta?
Pontuação 1
2 comentários
يرجى توضيح أكثر هذا قليلا
por
@tcampo what happens when you do replace the batteries? does it then turn on?
por
Adicionar um comentário
1 resposta
Solução escolhida
There may be several reasons why your device may not be powering on. Following are the common ones:
  • The battery may not be sufficiently charged. It may discharge automatically if not used over a long period of time. In this case, simply charge the battery. Also, check to make that the battery is inserted in correct orientation.
  • The battery terminal may not be clean. You may clean the terminal with microfiber.
  • External temperature also effects the way the camera functions. Thus, make sure to not use the camera when the temperature is above or below 0-40° C. Condensation might occur if the camera is moved from extremely cold temperature to a warm environment, which could prevent the camera from functioning properly. In that case, let it come to room temperature and allow the condensation to evaporate naturally.
  • For more information, refer to the troubleshooting page.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Thomas Campo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 1,299
