Ir para o conteúdo principal
Guias de reparo e informações sobre desmontagem de laptops de todos os formatos, tamanhos e cores.
18861 Perguntas Visualizar todos
A lot of modern notebooks have no back access panel. Why?
Hi, a lot of modern notebooks have no simple back access panel to change hd or ram, do you know why? So, swapping a hard disk or upgrading a ram module requires to tear down the notebook to the mainboard—and, if still under warranty, this operation could invalidate it if something goes wrong while opening the laptop.
Do you know why hp, for example, builds laptops of this kind? Thanks for any reply to solve this mystery.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
@uzugiulio as you can imagine this will all only be speculation. Only the manufacturers will know the answer for sure. I could imagine that this is partially done so that people like you and I cannot service our hardware. Anytime something breaks you will have to go to an authorized service center. So it'll keep the end user away from doing repairs. Secondly, due to change in architecture i.e. soldered RAM (not replaceable) and SSD card instead of hard drives will ultimately require more of a teardown than a simple hatch to replace parts. For as long as consumers demand faster, smaller and more efficient hardware, this trend will most likely continue.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Giulio será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 420
