Ir para o conteúdo principal
Lançado em fevereiro de 2009, o soquete AM3 é um soquete de CPU para processadores AMD com 941 pinos de contato.
Monitor not displaying anything because of CPU
My monitor is not displaying anything on screen. There is no fault in monitor, the fault is in the CPU processor, as I already checked my processor on other motherboard, my question is can i repair my processor. There is no damage as I can see on processor. It is clean.
AMD FX-8150.
Esta é uma boa pergunta?
Pontuação 2
4 comentários
How do you know it isn't the GPU or video card? What's it in? What does it do? If the CPU works in another machine, it's obviously not the CPU giving the problem, is it? What does an external monitor show?
por
If your processor has no damage ,
if the possible solution is clean your RAM before connect on-board or replace
por
How do I fix my cpu on my computer
por
CPU's can NOT be repaired.
por
Adicionar um comentário
4 respostas
Solução escolhida
mohityenugwar there is nothing you can do. If your processor has failed the only way to get things working, is by replacing the processor.
Esta resposta foi útil?
Pontuação 8
There is no realistic way to repair a processor itself. The only viable solution is to replace it. You should be able to find used Phenom x2/3/4s fairly cheap online.
Update (01/17/2017)
Also, most AMD FX series processors do not include integrated video capabilities. These CPUs were designed for gaming systems with dedicated graphics cards. There is a possibility there is, in fact, nothing wrong with the processor.
Pontuação 1
1 comentário:
Re-read the question ". . . I already checked my processor on other motherboard. . . "
por
U can change d processor can't b repair
Pontuação 1
It could also be the motherboard. Try the CPU on a different motherboard and see whether you get anything. Vice versa, you could also try a different CPU on the same motherboard. My guess is that most of the time, it's the motherboard.
Pontuação 1
1 comentário:
por
Adicionar a sua resposta
mohityenugwar será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 48
Ao todo: 4,043
