Ir para o conteúdo principal
The Coolpix P530 is a 16.1 megapixel digital camera with an impressive 42x optical zoom. This model was released by Nikon in February of 2014. It also goes by the manufacturer specific model name Nikon 26464 .
20 Perguntas Visualizar todos
How can I reuse a memory card from a different device?
Currently, I have a memory card from my old digital camera that I would like to use with the Nikon Coolpix P530. I am concerned with complications and losing data during the transition.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi,
You should be able to save the data already on the memory card to a PC. This will give you a copy of what you have stored on the card. When you install the memory card into the Coolpix, you will lose data if you have to reformat the memory card for it to work properly in the new camera. In any case, it may be that the Coolpix will not be able to 'read' the data stored on the memory card , because it might have been stored in a different format than what was used by the other camera.
If you no longer have your old camera, so as to be able to transfer the data from the card (installed in the old camera) to a PC and as you obviously wish to save the data from it then I suggest that you invest in a USB MultiCard Reader, unless your PC already has one installed, (here is a link for some examples http://www.ebay.com/sch/i.html?_from=R40...) that you can connect to your PC and into which you can insert a variety of different memory cards so that you can transfer the contents of the card into your PC.
Esta resposta foi útil?
Pontuação 2
As long as the memory card is compatible with the Nikon Coolpix P530 you may use it. In the camera's settings you can format any SD card to ensure compatibility with the device. Before formatting, make sure any images or video you want to keep are saved on a computer. The process of re-formating the memory card will delete all pictures previously saved on it. For more information on your issue or any other issues with the camera visit the Nikon Coolpix P530 Troubleshooting page its link can be found below .
Pontuação 1
Adicionar a sua resposta
Sydney Cardinali será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 246
