Ir para o conteúdo principal
O notebook Samsung Chromebook XE303C12-A01US possui uma tela de 11,6" e um disco rígido SSD de 16 GB. Este pequeno computador portátil permite fácil acesso à Internet e pode executar vários aplicativos web.
Can RAM be upgraded?
Can RAM be upgraded in this Chromebook? The module listed in the specs is 2GB DDR3L RAM. This is readily available in 4GB and 8GB kits. The Chromebook gets sluggish over time and this would be a great help
Esta é uma boa pergunta?
Pontuação 4
6 comentários
Your answer is INCORRECT. It seems that the RAM is soldered to the board (this is an SOC board, System On a Chip) and has no user serviceable memory slots.
por Compartilhar
How do you upgrade the chromebook
por Compartilhar
I think the problem is more or less that the chromebook gets sluggish over time and not that there very little ram.
Try a ram cleaner maybe?
With the newest Chrome OS, you might be able to install a ram cleaner app from the google play store.
( I have a black Samsung chromebook 3 )
por Compartilhar
which ram cleaner???
por Compartilhar
Ram cleaners don't help. You need to stop programs from running automatically. If you run a program to clean ram, that program is likely using ram, and it's just shutting down programs that are auto-running anyway. And process repeats once you reboot PC. In command prompt type in "services.msc" to bring you to page to manually change program startup behavior. Alternatively, press Ctrl+Alt+Del, go to Task Manager, click on startup tab to shut down from there. Microsoft OneDrive is one that auto runs.
por Compartilhar
Exibir mais 1 comentário
Adicionar um comentário
4 respostas
Solução escolhida
There are no RAM card slots; the RAM chip is soldered to the board. But there is another way to upgrade your RAM. You can enable swap memory, which uses part of the SSD as RAM : 1) Open a terminal by typing CTRL-ALT-T 2) Type this as it appears: swap enable 2000 3) Hit ENTER, then restart your Chromebook. You can make the RAM swap size whatever you like/ need, I believe it’s up to 6GB (swap enable 6000).
Imagem
Imagem
https://www.maketecheasier.com/create-sw...
Esta resposta foi útil?
Pontuação 6
2 comentários:
Thanks for the tip!
por Compartilhar
how do you undo (turn the RAM back into memory.)
por Compartilhar
Unfortunately No,
Like this type and many other Chromebooks the RAM is solderd directly on to the motherboard.
I'm Sorry
Pontuação 5
You could, I guess, with a little patience and a lot of luck, unsolder the RAM and put on a different one. It’s way easier to rewire Chromebooks than other computers…
Pontuação 1
3 comentários:
Does it need to be a solderable ram to be able to replace the original ram? Or can i replace the original ram with attachable ram
por Compartilhar
@tejaspatil5468 yes, it will have to be the same type of RAM. You can't substitute with removable RAM modules.
por Compartilhar
do you know which ram is used in Samsung Chromebook 3 ?
por Compartilhar
I like to eat Ram!
Pontuação 0
Adicionar a sua resposta
Matthew Carpenter será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 56
Ao todo: 20,797
