Ir para o conteúdo principal
Lançado em 2013, o TDK Life on Record A26 é um alto-falante portátil compacto e à prova d'água com Bluetooth e funcionalidade de viva-voz.
What does flashing lights mean?
I turn on the hard switch and push the power button, after three seconds the bluetooth and auxiliary buttons flash. Then device turns off and does not work. Is there a way to fix this? It is an error code but I can not find what it means. Any ideas?
Esta é uma boa pergunta?
Pontuação 0
9 comentários
please supply error code
por Compartilhar
The error code is the simultaneous three flashes of the auxiliary and bluetooth buttons. I do not know what that signifies but if you are a computer literate you would understand that it is an error code.
por Compartilhar
Hi, I realized it was an error code but thought perhaps a reset might clear it
por Compartilhar
Yeah, I tried the reset again, regardless. Still didn't help.
por Compartilhar
Hi,
Can't find any info regarding error codes, so am trying to eliminate possibilities. All these questions relate to establishing whether there is a problem with the battery and or the charging circuitry of the speaker.
1. What happens when you only connect a charger that is powered on? 2. Does the correct charging light i.e. red or amber show? 3. If red does it eventually change to amber? 4. Does it work properly when fully charged? 5. If not does it work properly when connected to the charger?
If the above do not point to a problem with the power:
Have you tried disconnecting the battery for a short period and then reconnecting it to see if this clears the problem? Here is a link that shows how to unplug the battery http://downloads.imationsupport.com/lor/...
2 part answer
por Compartilhar
Exibir mais 4 comentários
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi,
Here is a link that shows how to reset your A26.
http://support.tdkperformance.com/articl...
Hopefully this is of some help.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Tyler Pratt será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 34
Ao todo: 1,845
