Paper will not feeding
Cleaned all paper feed rollers.
Pick-up rollers not picking up the paper
Esta é uma boa pergunta?
Hi,
This link may be of interest to you. Scroll down to the post by 'jambro' (6th one down) for a description of a possible fix
Esta resposta foi útil?
The typical problem is associated with the cog sliding out of position along the drive shaft. This cog can be viewed by placing a mirror (facing upward) just within, and to the right, of the paper feed tray to view the drive shaft (running right to left) above the compartment. Also, use a flashlight to illuminate the area clearly. You will note a plastic cog (geared wheel) positioned on the shaft. When properly set, this should be positioned on the splines located on the right side of the shaft, which would align it to the gear that operates the paper feed rollers. It is not uncommon for this cog to dislodge from the splines and slide toward the left. Simply slide it back (right) over the splines until it is perfectly centered to drive the paper feed gear.
Equally common is that the corresponding splines on (within) the cog may become slightly worn (unit is entirely plastic after all), which allowed it to become dislodged in the first place. To ensure it remains in place, most DIY's apply a thin application of Super Glue to the splines on the drive shaft, then slide the cog into place - ensuring its gears are perfectly married (positioned) to/within the gears that drive the paper feeder. Allow ample time to "completely" dry before testing the printer.
Hope this solves your problem.
Thank you. I made a small hole in the bottom of the paper tray so I could work on it.
Thank you so much 😀 a small fraction of the little cog had broken off and I found it sitting on my paper. I didn't know what had happened until I read your post. Luckily the little cog was still attached to the bar and I was able to slide it back into place, it took a lot of frustrating fiddling about, and I seriously didn't think i was going to ever get my feeder to work again!!! But I have, there is just a couple of teeth missing on the little cog now, but it still manages to engage the rollers enough to feed the paper ❤️
You have been a blessing,
Sincere thanks 😊
20 Oct 2019: Problem was the little cog as explained above. It now works fine. Such a simple fix. Thank you genewcollins.
The cog fix was the first step. I also cut a hole bottom of the paper tray in order to make this easy to do using a dremel tool rotary cutting disc. I would like to point out that nylon and steel are not a great combination for super glue . I used a drop of E6000 adhesive on a thin wooden dowel --much better. The paper still did not grab. After this I had to use a small amount of automotive belt dressing on a swab to treat the rubber rollers behind the duplexing unit to restore their friction. This last step was magical!
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 40
Ao todo: 9,132
