Ir para o conteúdo principal
Teclado mecânico gamer da Cooler Master. Lançado com switches Cherry MX.
Replacing the Micro USB with a Mini USB
I would like to know how to replace the stock micro USB on this keyboard with a mini USB. My other keyboards use a mini USB cable and this keyboard has a micro USB; I would like to use the same cable for all my keyboards. Is this as simple as de soldering the micro USB and soldering in a new mini USB port?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
It would be easier to purchase a Mini USB Female to Micro USB Male Adapter (available on Ebay ) than to de-solder and re-solder USB ports as well as having to open a keyboard and then adapting the keyboard case to fit a bigger USB port opening.
Imagem
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
kevinpattison será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 19
Ao todo: 1,690
