Ir para o conteúdo principal
Um dispositivo portátil e recarregável que pode fornecer partidas instantâneas para carros e caminhões.
ac adapter lost need replacement
misplaced my ac adapter what input and output should I use to recharge example
input ac120v 60hz
output dc12v 500ma
what should I buy
Update (02/02/2016)
I need to buy an ac/dc adapter, an extension cord is not going to do the trick. I need to know what kind on voltage and output I need. The converter/adapter is lost . I would like to save the unit but do not know what size adapter to buy
Update (02/02/2016)
This a battery jump pack that is used to jump start a car. Some units have an ac adapter built in so you can charge the battery in the jump start pack. My unit has a spot to connect the ac adapter to the jump pack so you can charge the battery in the jump pack. My ac adapter has been lost. I know I have to buy a new ac adapter so I can charge my jump pack, what I do not know is if the input (from the ac adapter) is 120v 60 hz
I understand that the DC output needs to dc12v. I do not understand the milliamps. The battery in the jump box is 12v 10 ah ( what ever that is). I just want a new ac adapter to charge the jump pack with that is not going to damage anything.
Esta é uma boa pergunta?
Pontuação 5
11 comentários
i lost my plug for a master craft 4 in 1 jumpstart compressor 600 amp jumpstart system 260 psi air compressor 12 volt power port work light I need the plug
por
I lost my AC/DC Adapter for aMasterCraft Hum Starter 5 in 1 260 PSI Air Compresort
por
Ok I have the Preston jump It. Box. And I know to recharge it it has to use a cigarette lighter style charger.12vlt. to house plug. Where do I find something like that I've looked to no avail.
Can someone add the link to here so I can get back up.
Ty
por
Our dog ate the cord for the Mechpro Jump Starter 12v 600Peak Amps. Does anybody know where to get a replacement in Australia
por
I lost my adapter for my 500 Amp jump starter. What capacity adapter do I need to buy? The voltage, amps and anything else I need to know.
por
Exibir mais 6 comentários
Adicionar um comentário
7 respostas
Solução escolhida
Hi,
To charge the battery in the Powerstation jumpstarter, according to the User Guide (http://powerstationusa.com/manuals/PS110...), this is the type of extension cord you need. It will connect the Powerstation to any 120V AC power outlet http://www.amazon.com/HQRP-Extension-Pow...
Esta resposta foi útil?
Pontuação 4
6 comentários:
por
Hi,
Do not understand. The unit has a battery which is charged via the AC connection. The unit provides a DC output supply.
Do you wish to charge the unit battery using DC? If so, there is this warning given in the guide
"It is possible to overcharge the battery when re-charging using the DC outlet. Over charging the battery can cause permanent damage and decrease battery performance. Only charge using DC supply if a 120V AC outlet is not available. Charging the battery this way (via AC connection) also safeguards the battery as there is built in protection from overcharging and damaging the battery, which is not provided when charging the unit battery via the DC connection.
por
Hi,
OK I get it now. Your unit (which is not the one in the link in my answer I suppose) doesn't have an inbuilt adapter. In that case to charge a battery you need to do it a what is known as 'charge at the 10 hour rate'. This rate is the standard charge rate for batteries . It prevents damage caused by overheating etc, which may occur at higher current values. To get the charge current value, you divide the battery capacity, in your case 10AH by 10 giving a charging current of 1A.
However charging voltage for a battery should be higher than the battery voltage so as to prevent the battery wanting to discharge back into the adapter,.e,g, car 12V batteries charge at 13.8V. so ideally to charge your battery you need a DC14V 1A charger. 15V will do but keep a check that the battery doesn't overheat.
por
thank you this was very helpful
por
Accessories
DC charge cable
39" (1 m) 18 AWG with male to male
lighter plugs (part # 449-0187-01-01)
AC charger
Input: 120 V AC, 60 Hz, 11 W
Output: 13.5 V DC, 500 mA
(part # 074-1003
This is listed in the Owners Manual.
por
Exibir mais 1 comentário
Pergunta mais útil
Does this help at all
ac/dc adaptor class 2 transformer
model:ADC-1500700
I/P:AC 120v 60Hz 30W
O/P:DC15V700mA
Listed
54EG
E194707
copied from the back of the power adapter image in step 4
Teardown de estação de energia auxiliar de partida
hope this helps
Pontuação 5
6 comentários:
por
Lost my adapter for my jump starter its a car starter 1000 12volts dcthats all it tells me what adapter should i use to charge the unit oh it has 900 peak amps
por
Still does not answer the question where to buy just the cable part #449-0187-01-01
por
Will a output 12.0v -500ma work to charge it
por
Hi @amarlboroman ,
No, it won't bring up the battery to the required voltage
You need to apply more than 12V DC to charge a 12V battery, e.g. a car alternator puts out 13.8V DC to charge the car's 12V battery
por
Can I charge my power station/jump start using a battery charger. Gator clip red to red, black to black.
Pontuação 2
3 comentários:
Can you use a regular battery charger to charge the unit
por
Hi @ Dennis Green,
I'd say not.
You'd most probably damage the charging circuits and possibly the battery of the jump starter
Most car battery chargers initially put out ~ 4A when charging a battery, which reduces as the battery charges. They can do this as a car battery is usually a lead acid type (not as critical when charging as other types of rechargeable batteries) and there is no battery management circuits in play when you charge them directly from a car battery charger, i.e. battery disconnected from car and charger connected directly across battery terminals
Looking at the specs for the charging adapter provided above, it only needs 0.5A to 0.7A to charge the jump starter. Obviously it takes longer to charge the battery with this amount of current, but most probably it is suited to the type of battery (and battery management system) in the jump starter.
por
how can I charge the 4in1 powerpack if my battery is dead
por
Is the center tap negative or positive on the charger for the PEAK 700?
Their manual lacks detail for the charging apparatus…. it could be 24 volts ac, it could be 12 volts dc center tap negative, it could be 15 volts center tap positive… It could be anything!
I expect to see a polarity, voltage, and current rating however we see none. Also we do not know what the circuitry is inside this. Can’t make assumptions there. Most likely they have a buffer to control impedance and some circuitry for usb etc etc... You don’t know the design or whats going on internally to the device. Can you specify with 100% certainty? No, you can’t. Not without details.
To determine a compatible charging unit, you will need the following information:
1) specified center tap polarity ( positive or negative).
2) voltage ( ie 12 volts 24 volts etc etc)
3) specified current ( i.e. 400 mA)
5) the size of the plug (i.e 2.1 mm)
A part number would be great!
Just guessing on the polarity is a roll of the dice. Don’t gamble. Get the facts! It may have preventive circuitry to avoid damaging the unit if you use the wrong polarity but you don’t know . Until you find the mfg specs it’s risky to just plug it in. You might wreck it. Is that an acceptable risk? No it isn’t, not for me .
I have an email into the distributor and will update based on their feedback/findings.
https://peakauto.com/contactus/
Pontuação 0
Odd that nobody asked about polarity earier. You have to know this.
Postive Tip or Negative Tip? Most are positive tip but there is the chance it is negative.
I got this unit for 5 bucks so I am gonna try to charge the battery once I take it out and and or replace it. Then post what I find.
Pontuação 0
1 comentário:
Compressor not activating upon switching the button to on the position on the compressor letters. Any suggestions?
por
I bought a vector portable power supply has compressor lots of other things also I bought it thinking it was battery charger for 12v car battery it has the adapter for ac/DC so to charge my 12v would I just need a extension cord rated for this and be good to go
Update (04/11/2021)
Guess I don't need a cord bc I already have the adapter but I can't figure out is how do I charge the battery then bc I got the adapter and cables built in wat do I do hook those up bc when I do it's just a beeping sound and does nothing else says 13 .8 volts which is wat I need to charge but how do I know it is charging the beeping never stops box says compatible but on line and owner manual says nothing about how to do this spent 130 some dollars hate to take a hammer to it and set it fire bc I am out that much and doesn't do wat I bought it for
Pontuação 0
I just turn the &&^&^$ key til it starts then go skinny dippin
Pontuação 0
Adicionar a sua resposta
gdan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 69
Ao todo: 125,781
