Ir para o conteúdo principal
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
How to remove malware
Hello!
I have a big problem
I downloaded a gme using torrent once and i deleted it shortly after ebcause it was not working
SInce that day every couple minutes i get annoying pop-ups on all browsers even when reinstalling them , i also get pop-ups on steam and mostly everything that connects to the internet.
I scanned with avast couple times and i searched different folders but nothing works.
Anybody got a solution?
Thanks beforehand!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Hi,
Here is a link which shows, depending on your level of infection. how to install and run Malwarebytes
https://support.malwarebytes.org/custome...
Esta resposta foi útil?
Pontuação 3
2 comentários:
Thank you so much ! it worked!
por
Malwarebytes dot org, and Malwarebytes.com are two different apps. Dot org costs, and has Terrible reviews! See my reviews here: scroll down to it. https://www.sitejabber.com/users/robertl...
Dot com has free version I use.
por
Win32:Small-HUF trojan, TrojanDownloader:VBS/Psyme or similar malware is distributed through malspam campaign, illegal activation tools, fake software updaters, downloaders, and installers. Once they gain access to computer, they can damage your computer by opening your system's backdoor, draining CPU & GPU and memory. So, yes, this malware is dangerous and can cause system damage. In such case, you can run System scan with some powerful antivirus software for malware or viruses. For more details, visit the post through link.
Pontuação 0
1 comentário:
I would recommend going to helpdeskgeek.com and search for 2 articles. How to remove stubborn malware and How to remove viruses before your system boots. Using a bootable usb antivirus process is the safest and most effective method
por
Adicionar a sua resposta
Hikary Katsu será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 169
