Where is temperature sensor located?
Where can I find the temperature sensor on my 2003 Mazda Tribute 4 cylinder engine
Esta é uma boa pergunta?
@chasp you did not tell us exactly what temperature sensor you are looking for. It might also help if you tell us why. The 2003 Mazda Tribute with the 2.0L 4-cylinder does not use a traditional Engine Coolant Temperature (ECT) sensor that sits submerged in antifreeze. It uses a Cylinder Head Temperature (CHT) sensor that measures the temperature of the metal itself, and the computer uses that reading to calculate the coolant temperature.
Esta resposta foi útil?
Yes it's the coolant temperature sensor
under the intake manifold on the back of the alternator, better to remove the alternator so u can see the coolant temprature sensor.✌
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 42
Ao todo: 9,987
4 comentários
Where is the heat sensor located on Mazda tribute 2003-2007?
por Lavianna Stoops Compartilhar
where is the location of thermostat switch sensor of mazda tribute 2001 and to remove
por Ferdinand Quijon Compartilhar
Where is the heat sensor located?
Any video available?
por SOLOMON POKU-ASARE Compartilhar
