Ir para o conteúdo principal
O Asus U56E é um notebook Windows de 15 polegadas lançado pela Asus em 2011.
CPU fan making noise
ASUS U56E cpu fan is making noise when it runs. Sometimes it's louder than other times. I have a replacement fan ordered. Does anyone have any documentation on how to tear down the laptop and replace the fan?
Thanks much,
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Here is a link which shows how to dis-assemble an Asus U56E.
http://www.insidemylaptop.com/how-to-dis...
Esta resposta foi útil?
Pontuação 2
2 comentários:
WOW, was that detailed documentation. Thanks so much.
por
Hi,
Just a suggestion. Keep the screws removed at each step of the dis-assembly in a separate container. A lot of containers I know. This is so you will have the correct screws at each step when you replace them. Also take notice in case 1 screw is different from the others removed at that step in the procedure. Mark the screw hole so you know where it came from. Bit of overkill but it makes re -assembly so much easier. At a minimum, at least place the screws in a container, it's amazing how they can disappear!
por
Adicionar a sua resposta
nscarton será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 27
Ao todo: 2,349
