Ir para o conteúdo principal
Cobra 29 LTD Classic. Rádio PX (CB) de 40 canais e 2 vias. Possui indicador de aviso de antena, calibração de SWR, canal 9 instantâneo, capacidade de PA, controle de intensidade, supressor de ruído selecionável e ganho de RF.
blown internal fuse or link
positive and negative touched and blew something inside
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
The fuse is inline with the power cable. Here is a link which shows you where it is.
Substituição do fusível do Cobra 29 LTD Classic
If the fuse is blown and a replacement fuse (ensure that you replace with the correct rating fuse rating is usually stamped on silver cap of fuse e.g. 12V 2A etc) blows immediately you connect it, then there is probably a short circuit on the power input.
If you find that fixing the fuse didn't solve the problem and it doesn't power up, here is a wiring schematic which may assist you to find out what is wrong.
http://www.freeinfostuff.com/CBs/29LTD.p...
Here is a link detailing a solution by someone who had a similar problem http://www.radiomods.co.nz/forum/viewtop...
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
tree será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 27
Ao todo: 4,208
