Ir para o conteúdo principal
O Micromax Canvas 2 Plus A110Q é um smartphone Android dual SIM da Micromax Mobile, lançado em maio de 2013.
facing OS system issue
I have a Micromax A110Q Canvas 2 Plus phone whenever I start the phone the canvas word comes on the screen as if it is starting but it gets stuck to that only & my phone doesn't start. The display remains the same i.e. canvas written on the screen. nothing happens after this.
Kindly Help.
Regards,
Ratan Singh.
singh.ratan012@gmail.com
Esta é uma boa pergunta?
Pontuação 0
2 comentários
I have done the same but nothing changes still whenever I switch on my phone screen comes p by writing canvas on it & after that it gets stuck nothing happens later to this.
por Compartilhar
Hi,
I found this link which may be of interest to you. http://forum.droidarena.in/Thread-How-to... First he states that you press 3 keys (power + vol up + vol down) to hard reset. Different to what I have found (and you as well) elsewhere. Maybe you could try that before deciding IF you want to try his other option.
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
You need to hard reset your phone.
Before you do this make sure that the battery is fully charged.
Warning : A hard reset will restore your phone to factory default. You will lose all downloaded apps and user data!
To perform a hard reset do the following:
1.Turn off your phone
2. Press and hold the Volume Up + Power button (both together) until you see Recovery mode.
3. Release both buttons.
4. Select option "wipe data/factory reset" from the menu.
(To scroll options use Volume buttons, and to confirm press Volume Up key for 3 seconds).
5. Then confirm "yes" by Volume Up.
6. In the end accept (confirm with Volume Up key) operation "reboot system now"
The phone should now reset, be patient it takes a few minutes.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Rats será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 359
