Ir para o conteúdo principal
O Dell Latitude E6410 é um laptop de 14" lançado pela Dell.
Bluetooth Card activation problem.
Hello,
I have Dell Latitude E6410, the Bluetooth indicator is exist on the top of F1 key, My WIFI is working , so do I have WAN card on my laptop?. In such a case why my Bluetooth is not working?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
In System Setup (BIOS) there is an area called Wireless where you can check that your Bluetooth is enabled.
( to enter system setup press F2 when you first turn on your laptop)
There are two options displayed.
1. Wireless switch : which allows you to determine the wireless devices that will be controlled by the wireless switch: WWAN, WLAN, and Bluetooth.
2. Wireless devices : which allows you to enable or disable the following wireless devices: WWAN, WLAN, and Bluetooth.
Here is a link to the E6410 service manual which describes the System Setup (BIOS) settings. http://downloads.dell.com/Manuals/all-pr...
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
haassir será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 29
Ao todo: 1,587
