Ir para o conteúdo principal
Released May, 2013. Display - 1200 x 1920 pixels, 10.1 inches. Chipset - Qualcomm Snapdragon APQ8064, CPU - Quad-core 1.5 GHz Krait, GPU - Adreno 320. Memory - 16/32 GB, 2 GB RAM. Android OS, v4.1.2 (Jelly Bean), upgradаble to v4.4.2 (KitKat).
21 Perguntas Visualizar todos
black screen and red led blinking 3 times
the lcd was broken after a drop. tried replacing the lcd assembly but now the tablet won't turn on. even with the old screen i can't seem to get it booted. tried al the button combinations but it didn't work. tried unplugging the battery for 10 min. still nothing. when i press the power button the led flashes 3 times, that's it...
any idea's ???
Esta é uma boa pergunta?
Pontuação 0
6 comentários
when you replaced the screen did you disconnect the power before working on the tablet or was the battery connected during the replacement?
por
yes, I disconnected the battery before working on it...
por
Just a question do You know there's a shift button for a reason Ibar
por
Cody, I'm here to help people with their electronics. My first language is dutch, second is french. So please excuse me for my english and if sometimes I forget to write I with a capital I...
greetings iBar
b.t.w. Do you know there are buttons for punctuation? ;-p
por
Yes I do I am sorry.
por
Exibir mais 1 comentário
Adicionar um comentário
1 resposta
Solução escolhida
iBar, this can be caused by a bad/drained battery. Make sure that you charge your Sony with a known-good charger/cable.
Esta resposta foi útil?
Pontuação 2
2 comentários:
all i needed was the original charger :-)
por
Adicionar a sua resposta
ifixshop será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 29
Duração total: 19,785
