Ir para o conteúdo principal
Cobra 29 LTD Classic. Rádio PX (CB) de 40 canais e 2 vias. Possui indicador de aviso de antena, calibração de SWR, canal 9 instantâneo, capacidade de PA, controle de intensidade, supressor de ruído selecionável e ganho de RF.
My rx/tx light turns red
When I key my mic the rx/tx light turns red. When I unkey it turns back green. I also cannot recieve anything coming in nor can I get out. Please let me know what you think
Esta é uma boa pergunta?
Pontuação 6
1 comentário
Mine does the same thing but no antenna light
por Compartilhar
Adicionar um comentário
8 respostas
Pergunta mais útil
Your tx/rx light should turn red when you transmit and be green all other times. Your ant light should not light up unless the swr is higher than 3.0; then there is a problem. A common reason for the ant light to light up is that the antenna is not grounded properly.
Check out this page from Firestik for more information on swr and cb's.
If your ant light is on when you transmit, stop using the radio and fix the swr. You will ruin the radio.
Good luck and enjoy your cb radio!
Esta resposta foi útil?
Pontuação 2
1 comentário:
the green light is suppose to be on whe cb is turned on .and red when keyed up.
por Compartilhar
first thing first, check the antenna RF cable
Pontuação 0
1 comentário:
Mine does the same thing but my ant does not light up when i key the mic.
por Compartilhar
My RX/TX turns red when I transmit as expected, Have no problem transmitting or receiving, My SWR as Advertised and Antenna light stays off, RX/RT light is green until transmit, Make sure that NB-ANL/ANL OFF
Pontuação 0
From what I was reading the NB-ANL/ANL help filter out the noise from the ignition system and other working parts of the vehicle that give off background noise. So, why do I turn this off??
Pontuação 0
1 comentário:
I wouldn’t turn off the NB/ANL. It filters out a lot of noise.
por Compartilhar
Ok sorry don't have an answer I have another question, my rx/tx red when I key up like it's supposed to, but I have mine on cal to calibrate it but the needle doesn't move to cal ... it doesn't move at all for that matter ... what gives !!?
Pontuação 0
To calibrate it you have to have it on ch 1 and ch 40
Pontuação 0
Check to ensure that you have selected "CB" and not "PA" on the face of the radio. If the radio is older, or has been mobile for some period of time, you may want to maneuver this switch back and forth a few times just in case it's has fallen prey to an internal contaminant.
Pontuação 0
I have had this issue in the past and for me the most common problem is the mic went bad. You could try replacing the mic and see if that helps. For some reason when the mic goes bad with the newer radios they won't transmit or receive.
Pontuação 0
Adicionar a sua resposta
Jake Harris será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 90
Ao todo: 48,360
