Ir para o conteúdo principal
Cobra 29 LTD Classic Antenna Cable Replacement
  1. Cobra 29 LTD Classic Antenna Cable Replacement, Power Cable: passo 1, imagem 1 %32 Cobra 29 LTD Classic Antenna Cable Replacement, Power Cable: passo 1, imagem 2 %32
    • Turn the power switch, the leftmost knob, counterclockwise to off.
  2. Cobra 29 LTD Classic Antenna Cable Replacement: passo 2, imagem 1 %32 Cobra 29 LTD Classic Antenna Cable Replacement: passo 2, imagem 2 %32
    • Turn the device around and firmly pull the power cable plug to remove it from the radio.
  3. Cobra 29 LTD Classic Antenna Cable Replacement, Antenna Cable: passo 3, imagem 1 %32 Cobra 29 LTD Classic Antenna Cable Replacement, Antenna Cable: passo 3, imagem 2 %32
    • Unscrew the securing cap counterclockwise from the antenna connector.
  4. Cobra 29 LTD Classic Antenna Cable Replacement: passo 4, imagem 1 %32 Cobra 29 LTD Classic Antenna Cable Replacement: passo 4, imagem 2 %32
    • Gently pull the antenna cable to remove it from the back of the radio.
Conclusão
danperoni
Membro desde: 10/18/13
503 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 11-37, Amido Fall 2013 Membro de Cal Poly, Team 11-37, Amido Fall 2013
CPSU-AMIDO-F13S11G37
Membros da 4
Autoria de 9 guias
Um comentário
I dislike that kind of antenna plug. To easy to put together wrong. Better to find a pl259 plug that gets soldered. YouTube must have a video on it somewhere.
rrmanning06 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 21
Últimos 30 dias: 35
Duração total: 2,255
